Question graphic card help
Smoker_2
152
Hey I put in my older RX 5700 TI 8gb It works well on games max settings at 1080p 150 fps + no screen tearing no overheating stays around 49c to 65c
I have the Asus Strick My problem is When I watch movies on Netflix or prime My pc will lag up after about a hour into the movie then when its response I have white lines when I move the browser.
AMD Radeon RX 5700 XT 8gb
Baseboard Product ROG STRIX X570-F GAMING
CPU AMD Ryzen 7 3700X 8-Core Processor, 3600 MHz, 8 Core(s), 16 Logical Processor(s)
corsair 32g ddr4 ram 3600 MHz
Asus Tuff gaming monitor 1080p fast ips 1ms
I'm getting 20% more then my order card
im looking in the event veiwer in this is what it says
The program explorer.exe version 10.0.26100.4484 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
What is the make and model of your older card? Did you use DDU to remove all GPU drivers(intel, AMD and Nvidia) in Safe Mode, to later manually install the latest GPU driver sourced from AMD's support site in an elevated command, i.e, Right click installer>Run as Administrator(assuming you're on Windows OS)?
CPU: Amd ryzen 7 3700x
CPU cooler: cooler master Aio
Motherboard:ROG STRIX X570-F GAMING
Ram: cosair vengence pro 32gb 3600
SSD/HDD: 500gb selcon power m.2 2 silcon power 250 ssd
GPU: RX 5700 TI asus strix
PSU: cosair 750 gold about 7 years old
Chassis:??
OS: Windows 11 64 bit no I didnt use DDU but I can use it in reinstall drivers
