Geko26
12
I just bought a evga model of Geforce fx 5900 128mb. Why is the FPS in games so low? I made sure nview is set on standard so my other monitor isnt hogging some speed or w/e, but im only getting 4300 marks on 3dmark '03. I have the newest nvidia drivers too along with dx9b and all that. Help plz?
cleeve
Illustrious
Are you running 3dmark with AA or Anistropic filtering enabled?
What's your CPU? (Although it isn't a huge factor in 3dmark03, it is still a factor...)
Radeon 9500 (modded to PRO w/8 pixel pipelines)
AMD AthlonXP 2000+
3dMark03: 3529
Geko26
12
I ran it with the default settings (nothing enabled). I am running a p4 2.66 w/o hyperthreading. 512DDR PC-3200 ram. I just listed the graphics card in ebay, but i still want to know why it was getting low fps, maybe ill get the 256mb version of it or just go ati.
Caimbeul
378
its a non pro i take it?
<i>Mmmm Dawn AND Eve at the same time...Drroooooll
<b>XP2100+, 2x512Mb PC2700, ASUS A7N8X, PNY 64Mb Ti4200. :cool:
cleeve
Illustrious
256 megs makes absolutely no difference in performance over a 128 meg card. All it means is that it can hold bigger textures, and there are absolutely no games available desaigned to use 256 megs of textures at once.
Is that such a bad score for a 5900 non-ultra? Sounds about right to me.
AMD AthlonXP 2000+
3dMark03: 3529
Geko26
12
I just dont understand how they have high mhz speeds and can suck so much. How do the engineers mess these things up? Do they not test the cards before they make them? lol
Geko26
12
I know 256mb makes no difference. I know alot about graphics cards and all that, just wondering why this one is sucking ;)
Latest posts
