Hello,
I have a Power Color Red Devil RX 580 8GB card which is a hand me down from a friend.
He was using many of these for mining but gave this to me after he sold all his gear.
The first day, it powered up and worked fine for about an hour but stopped getting detected after a reboot.
There is a "Red Devil" light that still lights up but the fan does not spin at all during startup and not even the BIOS screen comes on through the monitor.
Testing with my older card, screen shows back up in the same slot, same monitor.
I've tried flipping the light and OC/Silent switches but nothing.
Tried opening and re-applying thermal paste which did not fix it either.
Attaching a picture of the board to see if there is anyone that could help me fix this card.
I do understand this is an older card and fixing it might be more effort than it's worth but hoping I can understand hardware better through this.
Thank you in advance for any tips or guidance!
View: https://imgur.com/qhZTb2A
View: https://imgur.com/jbLfS4S
Had some issues inserting the imgur image so adding as a link.
