Graphic Card Options for i7-920 System
da_park91
87
Hello,
I posted a question on this forums on a different section, and got great feedback.
It was between X4 955 BE vs i7 920 systems, and based on the advices I chose the i7 920.
However, I'm not really sure what graphic card would be best... because there are so many options.
My max budget for the card would be around 400, so I could get
XFX or Sapphire HD 4870x2 360~
XFX or Sapphire HD 4890 CF 380~
XFX GTX 275 SLI 410~
XFX GTX 260 core 216 SLI 320~
EVGA GTX 285 1gb 330~
EVGA GTX 280 SLI 375~ (someone i know, who opened two for reviews, is selling them a bit cheaper)
(NEWEGG PRICES)
which option would be the best one?
I'm planning to use the card(s) until the new graphic cards (i.e. nvidia 300 series and ati 5000 series) prices drop,
or until a game that i really like that uses DX11 to its max comes out.
Thanks!
Well yes I am planning to upgrade, but not right away... probably some time next year august or so I'll upgrade most likely. Still think 2 gtx 260 is enough for now?
What motherboard are you using? Not all support both sli and crossfire. if the one you are looking at does great but let us know the motherboard and psu you are planning on using.
Wow tough decision. I would probably go with either 2 4890's or the 2 280's. If you oc the 4890's or buy factory oced ones, you should be able to hit the same speeds as with the 2 280's. I guess it depends on what games you like to play.
I like playing World of Warcraft (and other MMOs I guess), high end FPS games (crysis, crysis warhead, etc), single player RPGs (oblivion, fallout3), GTA4, Prototype...
and planning to play starcraft II and diablo III.
Also, is my corsair 750w powersupply good enough for these SLI/CF setups?
What resolution are you planing at gaming at?
I have one GTX 260 and I am sure 2 would suffice for any resolution 1920xx1200 or less.
do all games run on 1920x1080, or do they need the x1200 ratio? ive heard that old games don't, and if im wanting to play CSS, will it run on 1920x1080?
Instead of buying a 4870x2 for 360 why don't you just buy 2x 4870's for 260? Then take the extra 100 and buy some games, or ram, or another hard drive.
To answer your psu question...
A 650TX will run Xfire 4890's so I think you're good.
Corsair is win.
With a 650tx you'd have to use molex/pcie adapters.
The 750tx has four 8 pins I believe so IMO, the 750 would just be prettier in terms of cable management. And your efficiency may be 1-3% higher. Big deal. Get the 750.
You'd still be getting more bang for buck on xfire 4870's.
Imo.
