Graphic Card Problem (Freezing after 5min or Fullscreen Load)
Ace Million
12
AMD ANTHLON X2 DUAL CORE PROCESSOR
NVIDIA GEFORCE 61650SE GRAPHICS
2GB DDR3 MEMORY
EMACHINES EL1352G-41W
POWER SUPPLY 220W
CARD I INSERTED WAS MSI RADEON HD6450
Worked for like 5 minutes or untill I tried to load Mugen (Videogame engine)
Worked on my bro cpu with also has Slim Emachines with same watt. He dont have intergrated NVIDIA
Do you guys think that NVIDIA Is the issue with the Card staying loaded
Ok when when you pc starts to boot up it will say either hit delete key f 12 or something like that to enter the bios in advance or some where in there should be disable onboard chip or igp that all I can find at this time and your card should be the main then you must disable your onboard chip in the bios look for it when you reboot either f something or delete key to enter it
Okay I manage to change it from Auto to PCIE. BUT NOW WHEN I INSERT THE GRAPHICS CARD AND GO BACK TO THE BIOS IT CHANGES IT BACK. WHEN I LEAVE IT OUT IT STAYS IN PCIE. WHEN I PUT IT BACK IN IT GOES TO AUTO. AUTO ONBOARD AND PCIE ARE THE CATEGORIES IN THE SELECTIONS. Also do you believe its because of NVIDIA? or that wouldnt have anything to do with compatibility with AMD or is it the powersupply?
PCIE Is pci express 2.0 or 1.6 did you hook your monitor up to the video card? not the onboard one? Yes AMD is radeon not ati anymore whats the deal with nvidia? Did emachines put a Nvidia motherboard in the computer? It has nvidia gpu you should be able to disable it here is a list of specs on your machine
http://www.microcenter.com/product/388110/EL1352G-41w_Desktop_Computer_Refurbished#tab-specs
http://www.techspot.com/community/topics/problem-installing-new-graphics-card-on-emachine-onboard-graphics.41175/
http://www.youtube.com/watch?v=-ebVsCG-lXs
check those links out it may not be possible...
the card is 2.0 I hook it up to monitor up to the video card. AND YEA IT has NVIDIA graphics. I believe intergrated. And that is the exact specs. The one he is hooking up is the video is the one my bro has. Hooks up perfectly the model I have which is a "better" if you can call this better model than his. I have done no work to my cpu at all and added in nothing. It loads up fine, then freezes after start pass windows or five minutes time.
