hello first post here seeking help
this is a 4 months old build. first time i played a game was very smooth and everything looks good.
however on the first week since i got my pc i noticed screen tearing on my tv i had to use v sync that limited my fps to 30
now im experiencing things like artifacts in some games similar to this sometimes bigger
View: https://www.youtube.com/watch?v=jt7QmXH9cx0&feature=youtu.be
(not my video)
when i play Middle-earth - Shadow of War the game crashes after some time with something like "Instance of GPU is suspended "
when i try to run MSI Afterburner scan i get error with code 3 (NVSMI folder is there), running the test gives confidant of 9% with stock values (sometimes it freezes)
adjusting the graphic settings and resolution in games doesn't make a difference
Im using HDMI to connect my pc to my 55" SONY BRAVIA TV 60Hz (tried different cables)
graphic temp always below 65
very hard to rma due to the location im at unless its very necessary
CPU: i7-9700K
Motherboard: MS-7B17
Ram: 16 GB
SSD/HDD: TEAM T253LE240G / WD Blue 1TB
GPU: NVIDIA GeForce RTX 2070
PSU: Masterwatt 650 Bronze
Chassis: MasterBox Lite 5 RGB
OS: Windows 10 pro
Sorry for my English
thank you
(not my video)
CPU: i7-9700K
Ram: 16 GB
OS: Windows 10 pro
thank you
