Right, Hi Guys
Basically i need some help, i bought a new computer made by "Medion" and it works fine but i want to upgrade the graphics card on it, but i don't know if my motherboard or other components would be compatible with it.
The graphics card im interested in is;
https://www.aria.co.uk/Products/Components/Graphics+Cards+-+GPUs/Graphics+Cards+-+NVIDIA/GeForce+GTX+650/Asus+GeForce+GTX+650+DirectCU+1024MB+GDDR5+PCI-Express+Graphics+Card+?productId=53482&rqcType=new#rqc
And my Motherboard model is a MS-7658
Also need to know if my case will be able to fit the Graphics card in so here are the measurements;
Width - 180mm
Depth - 390mm
Height - 360mm
My weak area in computing is compatibility and sizing so please help
Width - 180mm
Depth - 390mm
Height - 360mm
