Graphic cards and power supplies
DuncNewt
I have a Dell Optiplex 760 with a 3400 series card in it. The power supply in 304 w. I want to upgrade to a faster card. What is available without a replacing the power supply?
the fastest card you can plug into your system is 6670. but you have to make sure your mobo have PCI-E 2.0. if your mobo have PCI-E 1.x then look for 5670 with PCI-E 2.0 standards (means not the one with PCI-E 2.1 standards). the card is a bit slow than 6670 but it should work if you mobo was using PCI-E 1.x standards.
