Hello guys, I'm using a second hand Optiplex 780 case with a PSU 235W supply and a Geforce 310 🙁
On the Geforce website it says my Geforce 310 needs 30.5W supply and Minimum System Power Requirement 300W but I find it normal to use my Geforce 310 with 235W supply (Model: l235p-01). So what is mininum system power requirement really mean?
Can I upgrade my VGA to GTX 750 which need 55 W supply and minimum system power requirement 300 W? Will it fit my small form factor case?
What is the different between PCI-E 2.0 and PCI Express 3.0 Bus support? If I correct, all VGA can plug in all motherboard right ??
Here is the picture of my PSU
Thank you for the help
(sorry for my bad English)
