graphic driver problem
jkeyvan
Commendable
Jul 20, 2016
Hello
I have a problem with my graphic driver ; i have changed the resolution of my computer in my Intel_graphic program. But unfortunately i set the resolution much more than the compatibility of my monitor.
My monitor denies to display,because of unusual frequency.
then I boot in safe mode then although I reinstall it, again the same problem is here.
what can I do?
thank you
jkeyvan
Commendable
Jul 20, 2016
Thank you Albionm00n :)
I'd changed it in a program named Intel_hd_graphic but in safe mode it doesn't work and also after disabling the driver in Normal mode it doesn't run.
Yes I can boot my computer after making this driver disable,but I haven't made a restore point to restore my setting ........
I've tried to roll back my driver but it doesn't help.
Albionm00n
462
146
Hmmm...a little tricky for sure. Here is something to try...Right click on your desktop and see if it allows you options for graphics...you may be able to make the change back through display settings. Also, maybe there is a more current driver available that can help. Maybe a check on Intel's site can help: https://downloadcenter.intel.com/
Brainstorming........
jkeyvan
Commendable
Jul 20, 2016
Really thank you Albionm00n
Albionm00n
462
146
You are very welcome. Any luck yet?
