Question Graphical Glitch in Bios when using main monitor.
Jun 28, 2022
Hi all,
I am having issues accessing my BIOS when using my main gaming monitor.
It is an MSI Optix MAG272CQR.
I have just installed new mobo, cpu, ram and power supply. Everything works as it should, no problems with start-up logos showing, will boot into windows fine etc. However when I enter the bios my screen is black with only a small strip showing at the top of the screen.
I have updated the Nvidia DP driver which allowed me to see the start-up logos but still having the same issue.
The bios will display without issue on a basic 1080p monitor using HDMI.
Its frustrating having to plug this old monitor in every time I have to enter the BIOS.
Does anyone have any ideas on things I could try?
Thanks in advance.
Specs:
CPU: 12700f
Mobo: B660 AORUS MASTER
RAM: Corsair 16GB
GPU: Strix 980
Lutfij
Did you reinstall your OS when you swapped the motherboard out? While in OS GUI, use CPU-Z to see what your current BIOS version is for your motherboard. Make and model of your PSU and it's age?
