Not sure whether this is the appropriate section, but I'll put it up anyway. I just got Rome 2 a few weeks back, and I noticed that in the loading screen it says "Warning: Graphical Memory running low".
I can let the game use the system memory, but I would like to know whether this has something to do with my GPU. I use a GTX 550 Ti 1 GB GDDR5 and I want to know whether my GPU is not able to handle the game. Also I don't know whether its the GPU or the memory of the GPU that's causing this.
So, if I'm going to have to upgrade, should I just get a better GPU of the same memory (1GB) or pick up something that is bigger than it currently is(2GB).
If I have to upgrade, what would be a good choice in $160~$180.
Thank you.
P.S: Here's my specs
Intel DZ68ZV Motherboard
Intel i5 2500k @ 3.3 GHz
4GB RAM
ASUS GTX 550Ti 1GB GDDR5 GPU
Thank you.
4GB RAM
