Searching around this seems the hot spot for friendly helpful advice. I am a noob concerning computer hardware I know just enough to get me in trouble and get lost in the jargon.
I am running a custom build PC from scratch from a few years ago. I am recently encountering a reoccurring issue of getting "noise" pixelated speckles dancing around, BSOD when running games and higher end application crashes. Coincidentally this led me down a path of getting some software that gives me some temperature feedback. A replaced and upgraded heatsink has saved my CPU, but that hasn't resolved my Graphics problem nor has it helped my video cards keep cool(according to speedfan idleing at about 60 degrees). Any advice would be much appreciated to help me resolve this issue(s) as it may be one in the same.
System Specs
Case: Antec 9000 series
Fans: 2 Front 120mm (air in), 1 rear 120mm (air in), 1 Side 120 mm (air in), Top 200mm (air out). (note the Heatsink is a Thermaltake Black Widow Spin Q(has a built in fan)).
Motherboard: EVGA 132-YW-E178-FTW
Processer: Intel Core 2 Quad Q 6600 @2.4GHz
Video Card: 2x NVIDIA GeForce 9800 GTX/9800 GTX+ (SLI) Mounted to the top and bottom slots (may be to close to the power supply but I don't know what creates more heat a power supply or a video card)
Memory: 2x MUSHKIN 2GB DDR2 -1066 (I hope that is the right terminology)
Power Supply: Dunno
Hard Drives: I think are irrelevant but will include if needed.
EDIT:
OS: Windows 7
System Specs
Power Supply: Dunno
EDIT:
OS: Windows 7
