Graphics card and cpu for first Build
thedogfather89
18
Hi Guys
Im looking to build a computer for the first time and ive come up with the following components so far but im having a bit of trouble trying to find the best graphics card and psu for my rig.I have a buget of €200 to €250 for both the psu and graphics card any help would be greatly appreciated Thanks
Asus P8Z68-V PRO/GEN3
Intel Core i5-2500 3.30GHz LGA1155 6MB
Corsair 16GB (2 x 8GB) LP Vengeance 1600MHz DDR3 240-pin DIMM CL10
Zalman Z9 Mid Tower Enclosure Case
Sumukh_Bhagat
1,524
88
If you play BF3, Crysis 2 etc then go for 660 Ti.
If you play Dirt Showdown, Skyrim etc then go for 7870.
Both cards perform better than the other at several games.
I guess the games which show a AMD logo on startup like Dirt showdown, Sleeping dogs etc favor their AMD GPUs.
Check all the games shown in this review, it will help you understand :-
http://www.tomshardware.com/reviews/geforce-gtx-660-ti-benchmark-review,3279.html
And get a 600w PSU if you'll overclock anything.
Or else get a 550w PSU if you'll not.
Sumukh_Bhagat
1,524
88
I'd rather say go for 7870. Because its a 3 fps less in games like BF3 from GTX 660 Ti. (Not much difference).
But when you'll play Skyrim, 7870 takes a lead of 10-15 FPS from GTX 660 Ti. (Too much difference). The same happens in Dirt showdown.
And the 7870 is a little cheaper, hence you can get a little Money for your 600w PSU.
