Graphics card and monitor compatibility
nerd246
8
I have two MSI 390x's in Crossfire and was wondering about purchasing this monitor which is a BENQ (XL2730Z 144HZ 1ms 27 Inch Gaming Monitor with Freesync) and here is the link:
http://www.amazon.com/BenQ-XL2730Z-Monitor-Resolution-FreeSync/dp/B00TUK9D9K/ref=cm_cr_pr_product_top?ie=UTF8#Ask
I know that I have a 1.4 connection for HDMI and Display Port, but what is the best way of achieving (if possible) the 144HZ with two MSI 390's in Crossfire?
My build:
Intel 5820K at 4GHz
Corsair H80i
32 Gigs DDR4 RAM
Samsung 840 250Gb
MSI 390 (2) in Crossfire
Yes the monitor is compatible. In order for Free sync to work you have to use display port. As of now (and someone can correct me if I'm wrong) you must use the display port to use free sync. So that's the best option
