Graphics Card and Monitors Issue
Sep 2, 2018
4
So I've run into a problem. I'll try to go into as much detail.
I was using my pc the previous night perfectly fine, when I was finished I shut down my computer. The next morning I booted it up and everything seemed fine. I logged in and was on my desktop for about 5 seconds when both my monitors cut to black and said "Power Saving Mode" It's not an issue with the motherboard or cables or even the monitors, as I plugged them into my motherboard HDMI and DVI slots and they worked fine. I don't think it's a power supply issue because everything is powered up and working fine, even the graphics card. The fans are still spinning and a white light emits from it to show that it's receiving power.
I proceeded to look into my device manager and my graphics card is no longer there under display adapters. I went into my BIOS and it wasn't there either. So my computer isn't recognizing the card. This is what's leading me to believe it's a software issue. Maybe something within my computer conflicted with the driver or maybe something uninstalled? I'm not a computer whiz but I know some very basic things. I'm stuck and I would very much appreciate some help.
My GTX is a ASUS 970 STRIX, specifically this model.
https://tweakers.net/pricewatch/416129/asus-strix-gtx970-dc2oc-4gd5.html
As I stated earlier I don't think it's possibly a motherboard, monitor, or cable issue as it works when I use them on my motherboard HDMI and DVI slots. Can't be a RAM issue either because it still says I have 16gb ram in my computer settings.
So I tried again today and I got to my loading screen and it happened instantly. I went to my Event Viewer and it says critical "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly."
