graphics card and motherboard
Gopinath Gandhi
i have bought AOC 18.5 monitor. but my cpu doest support. so, i planning to buy graphics card- but now i camre to know through browsing that graphics card support ,windows 7 or vista not windows XP my cpu runs in windows XP,
Now pls do help me in buying graphics card supporting windows xp or
what should i do to operate my monitor ?
I'd need to know just a bit more to give my best answer--could you list some stats, like CPU model, etc?
Unfortunately, I'd say your best bet is to upgrade to Windows 7, and THEN look at hardware changes. Windows XP was definitely an awesome OS, but is soon to be put on the list of "legacy" operating systems, as Microsoft will officially be no longer supporting it this April. If you are still actively using it right now, I'm going to assume that some of your hardware is getting pretty old too.
However, if you're looking for the cheapest option to make it work, I'd just need to know more about your PC specs to give good advice.
Latest posts
