Graphics Card and PSU Upgrade for eMachines EL1358-G-51W
bdampier
Hello all,
I am currently using an eMachines EL1358-G-51W and would like to set up dual monitors. This computer is used for work only, so i will not need anything fancy. I was wondering if i would be able to add another graphics card without having to upgrade the power supply? There isn't much room for a low profile card, let alone a bigger psu. If this will be possible, could anyone recommend an inexpensive card to use?
eMachines specs:
http://i.walmart.com/i/rb/0088448398443.pdf
may be 6770 low profile:http://www.amazon.com/HIS-Express-Profile-Graphics-H667FN1G/dp/B0062HIQLU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1376194816&sr=1-1&keywords=hd+6770+low+profile
or
6450 low profile:http://www.amazon.com/Sapphire-Radeon-PCI-Express-Graphics-100322L/dp/B004XLPJNK/ref=sr_1_3?s=electronics&ie=UTF8&qid=1376194743&sr=1-3&keywords=hd+6450
your psu is :http://www.amazon.com/Logisys-Corp-Bearing-Supply-PS550E12BK/dp/B004MU8VCS/ref=sr_1_1?s=electronics&ie=UTF8&qid=1376192857&sr=1-1&keywords=550w+power+supply
Your gpu:http://www.amazon.com/XFX-Radeon-6770-Graphics-HD677XZNFC/dp/B005C31FJU/ref=sr_1_2?s=pc&ie=UTF8&qid=1376193426&sr=1-2&keywords=hd+6770
i think they will help you
Thanks for the quick reply! The only problem i see with the GPU is that it will not fit into my case. I only have about a 3 inch wide and a couple inches of depth to work with. I would need a Low Profile Graphics card. Any other possible suggestions?
or
