graphics card choosing help needed......
prithviraj murty
55
hi.......
i wanted to know which graphics card will best perform wiyh the amd fx6300 processor and 450w psu.......with value for money
1.http://www.flipkart.com/sapphire-amd-ati-hd-7770-1-gb-gddr5-graphics-card/p/itmd7tgzhnsn39yr?pid=GRCD7TGZHNSN39YR&srno=b_1&ref=237b29c5-1668-46b7-8e3e-5c903cfafabe
2.http://www.snapdeal.com/product/zotac-geforce-gtx-750-ti2gb/1121997704
The 750 ti is stronger and works with weaker power supplies.
750ti is around 10-20% better than the 7770 .. 750ti is a better choice ..but it costs 10,000 rupees
but for 10,000 rupees you can get an r9 260x which is 30-40% better that the 750ti
it is also compatible with your psu and will do well with your cpu
can't find the r9 260x only the r9 270x which cost 16,000 out of the budget
and my monitor resolution is 1366*768
