butler200269 :
butler200269 :
Just wondering what type of upgrade for my graphics card i should be looking at to go with this abovementioned motherboard if anyone can suggest some ideas please thanks
your motherboard can use any modern card literally pretty much anything made after 2006 although if your looking for card suggestions the main focus should be your power supply as that will be your limiting factor so one of these should work as they use a little less power than a 670
https://pcpartpicker.com/product/9TYWGX/evga-geforce-gtx-1070-8gb-acx-30-video-card-08g-p4-6171-kr
https://pcpartpicker.com/product/4XyxFT/gigabyte-geforce-gtx-1070-8gb-windforce-oc-video-card-gv-n1070wf2oc-8gd
Thank you very much for the reply
i inherited this machine from my son who built it a couple of years ago....but it needs a new graphics card and i wasnt really sure what was suitable. I have a couple of thoughts below if you could see what you think i would very much appreciate it
https://www.pccasegear.com/products/36691/xfx-radeon-rx-480-rs-4gb
https://www.pccasegear.com/products/31288/gigabyte-geforce-gtx-960-windforce-oc-4gb
https://www.pccasegear.com/products/31287/gigabyte-geforce-gtx-960-g1-gaming-4gb
https://www.pccasegear.com/products/34654/gigabyte-geforce-gtx-960-oc-mini-itx-4gb
I have a 750w power supply so im thinking thats fine....ive always used nvidia but my son recently built a new machine and went AMD for the first time himself so interested in what you might think....and these mini ones i have no idea about so just putting it out there again to see what you think.
Thank you very much for your help
Sure thing (i myself perfer AMD) if your talking about the cards you put down, the RX480 wipes the floor with the 960 if your wanting Nvidia, a 1060 is your better option. About the mini thing if your case is larger than this....
then there is no need to use one they run hotter and are sometimes cutback in terms of performance to keep power consumption and heat down. If you want to know which card to get just find out what games you plays AMD will do better with most EA games (mirrors edge, battlefield, fifa, titanfall, crysis, and quite a few non EA games) nvidia has games like (the witcher, warthunder, GTAV, skyrim, fallout, ect)
