Graphics card compatible with my system?
nonserviamgr
21
Hello, I got this pc build coming up:
Case: NZXT Phantom 410
Power supply: CORSAIR RM SERIES RM750 - 750 WATT 80 PLUS GOLD CERTIFIED FULLY MODULAR PSU
Motherboard: MSI Z87-G43 GAMING RETAIL
CPU: INTEL CORE I5-4670K 3.40GHZ LGA1150 - BOX
RAM: G.SKILL F3-12800CL9D-8GBXL 8GB (2X4GB) DDR3 PC3-12800 1600MHZ RIPJAWSX DUAL CHANNEL KIT
HDD: WESTERN DIGITAL WD1003FZEX BLACK 1TB SATA3
SSD: KINGSTON SV300S37A/60G V300 SSD 60GB SATA3 2.5 RETAIL
Monitor: LG 22EN33S-B 21.5'' LED MONITOR FULL HD BLACK
So i was thinking of getting Asus Radeon R9 280X 3GB GDDR5 R9280X-DC2T-3GD5.
Is it compatible with my above spec? Is the power supply enough? Also is the Monitor alright or gonna be poor graphic quality?
Thanks a lot for all your answers in advance!!!
yes 280x is compatible
Power supply is overkill for a single 280x
That is a decent monitor for its price
280x is overpriced in most areas, it perform similar to GTX770 so get the one which is cheaper
I dont see why it should be to much of a problem, but switching over to an nVidia card such as a 770 will definitely run cooler also the Radeon R9 series are highly over priced atm because of BitCoin miners. Also your psu is plenty of power I have an i7 and a GTX770 and I run it off a 750w as well. As for your monitor its 1920x1080 it should be fine.
