M mitulgogoi Honorable Oct 17, 2013 22 0 10,510 Mar 15, 2016 #1 anyone help me with the nvidia 8600 gt cooling update.
Solution Eximo Mar 15, 2016 How do you mean? Are you trying to replace the cooler on it? What is your budget for that? More then likely it would be better to invest in a newer GPU. You can pick up a Nvidia GT730 for $42.
Eximo Titan Ambassador May 27, 2010 28,454 5,820 144,340 Mar 15, 2016 Solution #2 How do you mean? Are you trying to replace the cooler on it? What is your budget for that? More then likely it would be better to invest in a newer GPU. You can pick up a Nvidia GT730 for $42. Upvote 0 Downvote Solution
