Graphics card doesn’t detect monitor?
Jan 25, 2019
Hi,
Okay so my graphics card is having issues recognizing my monitors. Whenever I plug in display port my monitor seems to realize something is happening so the light switches to blue and flips through all the connections then goes to No signal.
My HDMI port for some odd reason works and my right monitor is on, but when I try to open nvidia Control panel it tells me, “you are currently not using a display attached to nvidia gpu” yet my hdmi is plugged in.
As for my DVI that doesn’t work either, same thing as display port. Any ideas?
Update: the reason my hdmi was working was because my intel graphics was replacing the gpu so my monitor would turn on. my pc recognizes my gpu and the drivers are fully updated but no signal.
