I have recently bought a graphics card but the heat sink is massive and it doesn't fit in my case as it collides with my hard drives bracket. what i would love to know is if there is a way to decide what graphics card will fit in my computer.
Before purchasing you'll need to check the dimension of the card and compare it to the dimension of the case. Search for your case type and find the "supported VGA size". If that size is more than the GPUs dimensions then it's compatible...
yes, but it also means Video Graphics Adaptor - the card itself, which originally only had 15 pin D-SUB connectors which have become known as VGA connectors.
