Graphics card doesn't fit in case :'( please help!!! (pictures provided!
Vantage Midi ATX , OK so I opened the left side pannel, and there was a blue thing named "REMOVE FOR LONGER CARDS" if I can figure out how to structure it right, because my motherboard is facing the other way, and the pannel that can be removed is back of the motherboard, so IDK ill see if motherboard can be slapped on other way around.
Motherboard only goes in one way.
Figured it out, the little blue thing that can be removed is on the left side of the case panel because that's where the card sits, I have to weirdly tild the graphics card, and then change it's positioning once it's inside or else it wont go in.
