Graphics card equivalent of PS4(Not Pro) and Xbox One?
MamedovA
61
What do you think would be the Graphics card equivalent of the PS4 and Xbox One?
If consider resolution,graphic settings and FPS in games on PS4/XBOX One ?
Just I want to buy a new videocard to my PC was equal of this consoles:
Intel Core i5-3470 3.3Ghz
8GB RAM DDR3 1333 MHz
HDD:500GB
PSU:500W
If we're talking in terms of raw hardware performance, the PS4's graphics chipset should be a little below that of an RX 560 or GTX 1050. The Xbox One's hardware performance is lower still, probably closer to that of an RX 550 or GT 1030.
Of course, many games on these consoles only run at 30 fps, and many are upscaled from resolutions below 1080p, so in many games that kind of performance would be unsuitable if you wanted to run them at 1080p at equivalent graphics settings. On the PC, you do have access to graphics settings that can affect performance though, which gives you more control over how well a game runs on a particular graphics card.
I agree with madmatt30 that a GTX 1050 Ti would probably be a decent choice if you want...
I agree with madmatt30 that a GTX 1050 Ti would probably be a decent choice if you want to want graphics and performance similar to a console at 1080p, and the card's 4GB of VRAM should be fine enough for most games coming out over the next couple years. If you want closer to 60 fps at 1080p, then maybe a GTX 1060 6GB would be good. There's currently a shortage of AMD's cards in this price segment right now, causing them to be hard to find at reasonable prices, otherwise I'd also suggest the RX 570 / 580.
MERGED QUESTION
Question from MamedovA : "What GPU is Equivalent to the PS4"
If consider resolution,graphic settings and FPS in games on PS4.
I try to choose between RX 460 2GB and GTX 1050 2GB (Non Ti).
Must i pay more for 1050,or RX 460 will enough ?
My PC:
i5-3470 3.3Ghz
8GB DDR3 1333Mhz
HDD:500GB 7200rpm
PSU:500W
MERGED QUESTION
Question from MamedovA : "Is this PC equal of PS4 (Not Pro) ?"
That is an overestimation of the PS4's performance. The GPU is essentially a cut-down and underclocked R9 270, and that GPU is already somewhat slower than the GTX 1050 and RX 560.
