Hello dear mates,
my Radeon R9 Vapor-x OC 280x 3GB Graphics Card one of the fans stopped working, back after like 10 min to spine.. but seems lower.
he has lot of dust, hard to clean, was for bitcoin before got it.
Specs:
Graphics Card- Radeon R9 Vapor-x OC 280X 3GB
Core- Intel Core i5 2400 3.1Ghz
Memory- 2x8GB DDR3 1333Mhz G. Skill Ares
Power supply- SeaSonic 600W PFC 80+ 12cm Fan
Case- Sharkoon T5 Value Black ATX
Screen Resolution- 1920X1080
I know will get Bottle neck but not sure what most true to get, and worth by the price (in website).
I want get new one from KSP -> from the website list below, which one most recommended ?
http://en.ksp.co.il/?select=.1044..35..201..202..48..1358..47..45..441..347..99..859.&kg=&list=1&sort=2&glist=0&uin=0&txt_search=&buy=&minprice=934&maxprice=1587&intersect=&rintersect=&store_real=&store=KSP03
heared MSI Radeon RX 480 8GB GAMING X is good, or maybe Sapphire or Nvidia ?
+ What the different between 2x 8 pin and 1x 8 pin ? less voltage less heat ?
+ Before installing new Graphics Card, need remove all Drivers ?
Lot of Thanks for help me choice and answers.
Specs:
