graphics card for corel draw
cdnkoehn
I would like a graphics card to give me more performance using corel draw. Some of the drawings are large and need to redraw contours every time I make a change to the drawing. My computer hardware specs are: i7 4rth gen, 4770, 12 gig ram, 512gig samsung SSD & nvidea geforce gt 635 graphics card.
There are plenty of options available both from AMD and nVidia.
If you can tell your budget and your preference for AMD/nVidia, I will be able to help you out.
Nonetheless, You can go for a R9 280x or R9 290 from AMD or a gtx 770 / 780 from nVidia.
Both will give you much much much more performance than required and will be future proof.
