Graphics card for daily use & dual monitor
Abhishek Mishra
21
Hello everyone,
i'm confused after searching a lot on google and amazon.
Basically i'm looking for a budget graphics card which can give me good resolution and can support dual monitors (21-22 inches) at good cost.
I don't play games much and i would be okay if new graphics card work only at 720p settings for gaming.
I'm just looking for something which i can use for daily work with dual monitors.
I had looked at gtx 1050, gtx 750ti and some radeon cards.
After looking at all those, i got confused which one i needed from those.
Here is my system information
CPU: AMD FX 6300 Black Edition
RAM: Corsair Vengeance 8GB DDR 3
MOBO: Gigabyte GA 78 LMT USB 3 REV 5.0
PSU: Corsair VS 550 Watts
Cabinet: Cooler Master K281 Mid Tower Cabinet
CPU Cooler: Cooler Master Hyper 212X
HDD: Seagate Barracuda 1TB
Monitors : would buy 2 21 Inch monitors soon after this graphics card, would be great if someone would suggest those too
Thanks!
Do you already have this system?
Just get a 1050 it will last you as long as you use that pc. If it's too expensive look into a rx 460.
Yes i do have that system already, i'm just upgrading it
