Hello,
I am somewhat new to graphics cards and CAD and need some help. PLEASE HELP!!
Currently I run a CAD program for 3D modelling (making medical grade orthotics/prosthetics). Two programs run in the background, CopyCad and also PowerMill. The 'rendering' time and load time for using the programs is becoming painful to deal with. I am not about visual quality, I just want the speed to be as quick as possible. The size of the files are only about 10MB once completed, so they are not overly large. Some files can be as large as 80MB.
My work would take me half the time if I didn't have to wait for the computer/program to load. I do not really want spend $3k on a new computer just yet, but need to upgrade what I have as I believe I could make it significantly better with some advice.
The specs of my computer currently are:
Intel Core 2 Quad CPU Q9500 2.83Ghz
Windows 7 32 Bit
3GB RAM
NVIDIA GEFORCE 210
I can easily upgrade the to 64 bit Windows and have 8GB RAM. But just need help with the graphics card. Would changing the graphics card to a NVIDIA Quadro 600 make a big difference? I have been told for the work I am doing I am best using a Quadro rather than a Geforce card. Also if you think a Quadro card is the way to go, would there be a big difference for me between a 600 and 2000?
PLEASE HELP!!
Regards,
Dean
Windows 7 32 Bit
3GB RAM
NVIDIA GEFORCE 210
PLEASE HELP!!
Regards,
Dean
