T thehardyboys00 Mar 5, 2018 9 0 10 Apr 3, 2018 #1 I have a HP 6000 pro micro tower. I'm upgrading Ram and Graphics cards for a budget gaming PC What graphics cards can I use. Do I need LP or Dual Slot???? Help!!!
Solution James Mason Apr 3, 2018 Really old. https://support.hp.com/us-en/product/hp-compaq-6000-pro-microtower-pc/4023814/document/c01865757 Modern GPUs like the 900 and 1000 series from NVidia probably won't work. 700 and below should. Should work with full height dual slot cards though. But the PSU in the system most likely can't power them.
K King_V Illustrious Ambassador Nov 1, 2014 8,291 2,472 39,590 Apr 3, 2018 #2 Do these pics of the back and of the inside look like your system? this and this If so, then it looks like you don't need to limit yourself to low-profile or single slot cards. Upvote 0 Downvote
K King_V Illustrious Ambassador Nov 1, 2014 8,291 2,472 39,590 Apr 3, 2018 #3 The only downside is that if the BIOS is old, newer cards MIGHT not work. Hard to say without knowing how old the system is. Upvote 0 Downvote
James Mason Titan Jan 2, 2014 13,551 7 74,965 Apr 3, 2018 Solution #4 Really old. https://support.hp.com/us-en/product/hp-compaq-6000-pro-microtower-pc/4023814/document/c01865757 Modern GPUs like the 900 and 1000 series from NVidia probably won't work. 700 and below should. Should work with full height dual slot cards though. But the PSU in the system most likely can't power them. Upvote 0 Downvote Solution
