Graphics Card Help on 7 y/o hardware
Aetropos
Having some Graphics card crashing/freezing problems and looking for suggestions on a replacement. The card is only about 3 y/o and has worked great until here recently like it was holding out for me cause it knew i was going to get some Christmas cash... but i digress...
my budge is around 200$ but it's not a hard cap.
my current MOBO and Card
Thanks for any help!
For ~200, the best card available is the RX 480 4gb, if you are on neweggs newsletter, they have a few on sale for under that. Below that is the 470 and below that the 1050ti.
Depending on what CPU you have, you should be good up to a 1070. With the setup in my sig, I have been able to run everything so far on High+ settings. I run Forza Horizon 3 on all high settings and Fallout 4 on high (@1080p).
From Nvidia you're looking at either a 1050ti or a 1060. 1060 obviously better. AMD, you're looking at an RX 480. What CPU and speed? Obviously games that are CPU-demanding will bottleneck a bit more. 4ghz+ of the first-gen nehalem/westmere i7 still does well-enough.
