Graphics card help / recommendation
eludlow
Hi there.
I’m after a card with similar performance to the PNY XLR8 GeForce GTX 960 but in the short card form factor, not the long card which my current case doesn’t have room for!
Spec I’m after:
can output one display resolution up to 4096 x 2160, and two SD. Want to run x1 Dell P2415Q and x2 Dell U2412M monitors. Ideally all via DisplayPort but that’s not crucial. This is not a gaming rig, but will be pushing the Adobe suite (mainly Premiere, Photoshop and InDesign) quite hard.
Any recommendations etc welcome, thank you.
Ed
Maybe this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487093&cm_re=GTX_960-_-14-487-093-_-Product
