Graphics Card Help!
The_Legend131
30
Hi,
I have need a graphics card go run in a pcie 2.0 x16 slot.
I am building a budget pc for gaming, so I need the card to be below £70
Will it be capable of running bf4 (along with my athlon 5350 and 4GB ram) and minecraft?
At what FPS?
Thank you.
These cards are backwards compatible with PCI-E x16 2.0 & the best around your budget:
R7 250X (£65): http://www.ebuyer.com/634803-powercolor-r7-250x-1gb-gddr5-vga-dvi-hdmi-pci-e-graphics-card-axr7-250x-1gbd5-he
GTX 750 (£79): http://www.ebuyer.com/618545-msi-gtx-750-oc-1gb-gddr5-vga-dvi-hdmi-pci-e-graphics-card-n750-1gd5-oc
The GTX 750 is a decent bit quicker than the R7 250X (7770). Note that you also need a decent power supply as well, 20 Amps or greater on the 12v rail.
http://www.techpowerup.com/reviews/ASUS/GTX_750_OC/25.html
(Note the GTX 750 will be a smidge slower than the GTX 750 Ti)...
http://www.pcper.com/reviews/General-Tech/AMD-AM1-Platform-and-Athlon-5350-GTX-750-Ti-1080p-under-450
