Hi I have a Radeon Sapphire HD7850 1GB and I wanted 3 monitors so I have one in the hdmi port and the dvi port so I got an adapter for the 3rd monitor which was a DVI D to vga but apprently you can't use both DVI and DVI D
you have to use either the DVI or DVI D then display port and hdmi so You can't us e both the DVI ports is this true
