graphics card help ?
GamerChimp
41
So ive been building a computer and all thats left is the graphics card at first i was all for building this till i realised none of my friends are intrested in it so i will constantly be torn between getting a game on pc for good graphics and maybe mod compatibility and then xbox for playing with my friends and having a good laugh ...
but i guess if its only a graphics card left to get i may aswell finish it ? at first i was going for a gtx 970 but now i dont know due to it costing nearly £300 , whats a great card that will hold games on great graphics etc for my build but wont break the budget ?
my build is
I5 4590
ASrock Pro4
Hypercooler evo 212
corsair 200R case
g.skill 2x4gb
1tb western digital
windows 8.1
24 " monitor
drop the cooler and get Zotac GTX 970
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor (£149.15 @ Aria PC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard (£64.99 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£58.69 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£35.94 @ Aria PC)
Video Card: Zotac GeForce GTX 970 4GB Video Card (£255.59 @ Aria PC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case (£30.25 @ Scan.co.uk)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£46.99 @ Amazon UK)
Total: £641.60
Generated by PCPartPicker 2014-12-28 15:11 GMT+0000
You will get what you pay for in graphics cards at every price point.
For a balanced gamer, I suggest a budget of 2x the cpu cost for the graphics card.
By that reasoning, a GTX970 would be very appropriate.
It will need a quality 500w psu. This would be appropriate if you play fast action shooters.
Or, you could go for something like a GTX750ti which is a very competent low power card.
It will run on a decent 300w psu.
This would be appropriate if you play sims mmo's, strategy and slower action games
yes ive bought all these parts , i was recommended to buy a cooler as the stock one can be loud ?
also bought XFX 550W PSU +80 bronze
