Graphics card help.
Eonik
87
Hello, i want to know wich card should i buy, the processor is an Intel Core i5-4690K, and i want to be able to run GTA V, Battlefield 4, Watch Dogs, The Crew etc... without lag.
Zotac GeForce GTX 960 4GB AMP! Edition
EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+
Sapphire Radeon R9 380 4GB
once again get the 380 4gb you can get it for 203 and it's powerful enough to use it 4gb vram http://www.newegg.com/Product/Product.aspx?Item=N82E16814131673&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or a r9 380x for 209 http://www.newegg.com/Product/Product.aspx?Item=N82E16814202137&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
The R9 380x is better than the Sapphire Radeon R9 380 4GB ?
No i don't have the CPU yet.
380 4gb is better
what parts do you have?
Intel Core i5-4690K 3.5GHz Quad-Core Processor
ASRock Z97 Anniversary ATX LGA1150 Motherboard
Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1333 Memory
Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive
GPU: -
what psu are you gettting and also what is your budget?
I don't know the PSU yet, and my budged is 600-650 dollars. I made this:
PCPartPicker part list: http://pcpartpicker.com/p/WgQ6zy
Price breakdown by merchant: http://pcpartpicker.com/p/WgQ6zy/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($224.99 @ SuperBiiz)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard ($84.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1333 Memory ($36.99 @ SuperBiiz)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive ($38.95 @ Amazon)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card ($227.55 @ Newegg)
Case: Thermaltake Versa H22 ATX Mid Tower Case ($28.99 @ SuperBiiz)
Total: $642.46
Generated by PCPartPicker 2015-08-09 02:56 EDT-0400
Links not working
for the one that is on budget it will preform almost the same as your build but the one i build includes the psu in the price
and yes you will be able to play those games at least at high to ultra settings
Ok, thanks for everything, i might build the one that you sent me, i just want the PC to play some games at least on High without lag, and for that price, i think that i will build that one.
