Question Graphics card in PC build help
Jun 20, 2019
I have a GeForce RTX 2060 Graphics card in a silver stone milo 8 case. The problem is that the card is barley to thick for the case. Only a few millimeters. I was wondering if I could remove the back panel of the card to get a few more millimeters to make the card fit. It would be flat against a metal wall and I don’t if this will provide cooling problems. Thanks for any tips.
Edit, it says it has a Thick aluminum backplate.
M.AGamer
Proper
Feb 19, 2019
270
18
195
Don't ever do that sometimes it will ruin your warrenty getting a new case is better (losing 50$ is better than losing 350$ :).
