Graphics card is blocking motherboards front panel usb connector/hub?
shafe88
854
Anything I can do to fix the problem of my graphics card blocking my motherboards front panel usb connector/hub? My computer is an Acer Aspire TC-605 and the Graphics card is an MSI GTX 750 Ti. I managed to fix the hard drive issue by simply moving the hard drive to the 2.5 inch drive slot, but haven't been able to fix the front panel usb problem, I have the graphics card installed, but had to disconnect the front panel usb cable. The graphics so far is working perfect. My first thought was to just thro in a USB pci card with a front panel header, but afraid it might be too much my PSU.
Hear is my motherboard in my acer
http://www.ebay.com/itm/ACER-Inc-MS-7869-VER1-0-motherboard-/301363155279
Hear is my graphics card
https://www.newegg.com/Product/Product.aspx?Item=N82E16814127784&cm_re=msi_gtx_750_ti-_-14-127-784-_-Product
Amazon have any that's cheap? Looked and could only find one that's $14.99 plus shipping. Like to find one in the $5-$6 range.
That may just work, but a little concerned the graphics card fan won't get enough air. Hear is an image with the side panel off.
Your graphics card isn't a full double slot width card. It's more like a 1.5 slot width card based on the Newegg.com images you linked to. I don't think you'll have any problem with the card not getting enough cooling air.
Upon further inspection and measuring, looks like it's a no go.
