I just put together a brand new computer and I am not receiving a display when I connect my monitor to the graphics card. I do however still receive a display when I connect my monitor to the onboard graphics card - even with the new graphics card still in the PCIE-2 Slot. My BIOS is set to use the PCIE-2 slot as the "primary graphics adapter".
The graphics card is receiving power (has both an 8 and a 6 pin power input (what would happen if I plugged in all 10?), and the lights come on with spinning fans.
Looking at the motherboard's system browser, everything is detected with the exception of the graphics card in the PCIE-2 slot, which still shows as "empty", but... if I attempt to boot my computer without attaching the graphics card to the Power Supply I receive an error upon booting the computer that says "please power down the computer and connect this graphics card to a power source", or something to that effect.
I'm a bit confused, I don't think the PCIE-2 slot is broken because it can tell if there is a graphics card in the computer that is not receiving power. But, when it is receiving power, the motherboard doesn't "see" it.
I use a DVI cable, with an adapter on the gpu, but I have also tried to use an HDMI cable.
I've download the most recent BIOS for this board (P1.90), as well as any other drivers/software either provided by the CD that came with the hardware as well as what was available from the F-Stream utility program. When I scan for new drivers, nothing new shows up.
Unfortunately I don't have access to a different graphics card to see if it really is an issue with the motherboard.
The only thing I can think of, is maybe I was a little overzealous when putting my new computer together? I put the computer together and put the drivers for the graphics card on my computer before installing the motherboard drivers or the actual graphics card... don't know if that would cause an issue or not, or how to remove the graphics card drivers if it is causing an issue, they don't show up in the Device Manager for me to delete. The only display adapter that is in my Device Manager is my onboard graphics card that comes with the motherboard.
Here are my specs:
Motherboard - ASRock Fatal1ty H97 Killer
Graphics Card - MSI GTX 970 (GeForce GTX 970) Gaming 4G
CPU - Intel Core i5 - 4690 @ 3.5 GHz
Memory - 8GB (2x4GB) G.Skill DDR3 RAM
Storage - 1TB HDD
Power - Corsair CX600M (600W)
Here are my specs:
Storage - 1TB HDD
