Hello Tom's Hardware Forums!
My system is a Dell Vostro 400:
Q6600 2.4Ghz Intel Core 2 Quad
4GB RAM
500 Watt PSU
And until recently, I have been rocking a Radeon HD 2600 XT. I recently purchased a Radeon HD 6670 from MSI. So I uninstalled all of the AMD drivers and software, slotted the new card in, and fired up the dinosaur. However, the monitor told me that there was no signal coming from the DVI connector. the same happened with other monitors i tried with, so I ruled out the possibility of it being a monitor problem.
The next thing I did was plug my monitor directly into the VGA on the motherboard. Both the BIOS and Windows 7 worked fine, and i did a little digging around, and found that the system was not detecting the card at all; it was telling me that there was nothing in the PCI-E slot. The AMD driver installers would also bail out on me for not having an AMD card present in the system too. However, the fans were spinning on the card.
I then attempted to slot the Radeon HD 2600 XT back into the system. It worked, and the drivers installed without any problems. But I put the Radeon HD 6670 into the system and I was back to where I started.
Adding another interesting point to the mystery, the Radeon HD 6670 worked on my friend's system.
Does anyone have any ideas as to what the problem with this installation is? I should also note that this Radeon HD 6670 does not have a PCI-E power connector on it, so there's no way I missed that. But am I missing something here? The graphics card should have displayed some sort of signal, right?
Thanks in advance
4GB RAM
500 Watt PSU
Thanks in advance
