Graphics card not showing video with monitor.
Tony0783
9
Ok. Just put a new pc together. Everything seems to be working. Fans on graphics card are spinning and seem to be getting power to everything. When i hooked up monitor to gfx car via hdmi and dvi i did not get any display whatsoever. Tried the monitor on my ps3 and it worked fine. I have no onboard gfx card on motherboard but am about to try a different gfx card just to see what happens. Plugged sapphire into pci express 16x then plugged 2x 8 pin pci express power cord into gfx card and made sure i had good connection. I have 2 power cords coming from power supply that are 2x 8pin but not sure if i should try both of them. Obviusly im a newb but maybe someone can help me?
System:
Viewsonic 24in vx2453mh-led r
Cooler master storm scout
Vga sapphire hd 6950 2g r
Mb gigabyte ga-99fxa-ud3 am3+ r
Psu antec 750w hcg-750 rtl
Ripjaw gskill 4gb ram x2
Cpu amd phenom x4 970 3.5ghz am3 rt
Update: tried a different gfx card with the same result. I dont think i have a way to test cpu or motherboard right now. I dont think there should be any compatability issues but not positive.
Are you using the top PCI-Express x16 top slot?
Some mobo's default to only the top slot if using a single card.
Your PSU has x4 6+2 pins.The 6950 only needs x2 6 pins.So just use the 6 pin part of the 6+2 pins.
If you've tried a different card than I would think it's a defective mobo.Might have to RMA it.
I am so sorry guys. Thanks for your input but i missed a cpu cable i was supposed to hook up to the motherboard. Told you i was a newb. lol Anyways, now i have to figure out how to make an old hard drive work with my new pc. Prolly have to reformat it and reinstall windows?
By old do you mean IDE/Ribbion Cable old or just from your previous PC?
If their are no other HD's with OS's on it then it should work just fine(Plug&Play).Usually the OS will re-adjust to accommodate the new hardware.
If it doesn't work don't reformat it just re-install from the CD.It will put the old OS and everything else previous to the fresh install in a Windows.old folder.That way you don't loose anything.
