I Have an NVIDIA 770 4G. i have not used it for a few weeks. i was going to attempt to give it a spin again after a few weeks. when i used it last it worked perfectly Fine and as it was supposed to. But
When i plug in the PCI-E Cables from my PSU into the card and turn on the PC it turns on for 0.8 seconds then Turns off then does not turn on again unless i switch the power supply Off for 5 seconds and turn it back on from the back. it persist to do this issue. but with the 1st PCI-E Connector on the graphic Card. when i plug it in and not the broken one it works but does not display as it needs all Pins connected. this same issue happened With my AMD radeon RX 580. i have tried numerous PSU's and computers them selves i still get the same issue.
