Question Graphics Card PCI slot help
Nov 28, 2020
24
Does a PCI 4.0 card work with a PCI 3.0 slot?
If I upgraded the motherboard, would I have to get a new copy of win 10?
Nov 28, 2020
24
Current GPUs don't even use all the available PCIe 3.0 bandwidth.
NVMe SSDs can benefit from PCIe 4.0 but it doesn't really make a difference in normal, everyday computing, only synthetic benchmarks.
Well that's good to know, didn't even know PCIe 4.0 was a thing until after I ordered the card and I was like did I make a booboo?
Thanks for the help
ttower2020
Respectable
Nov 5, 2018
296
56
1,940
37
Gen 4 PCIe is more for future capability. Nothing released currently will be harmed by using it on PCIe 3.0 instead of 4.0, except for the fastest of NVMe SSDs, and that difference is still very minimal. That being said, the difference is also purely bandwidth. You could use a PCIe Gen 4 card with PCIe Gen 2 motherboard, and it will work, just at a possibly limited speed.
