Graphics Card Power Supply Requirements
Ragnar2615
6
I'm looking at getting a Radeon HD 7870 but it says that it has a 500W power supply requirement. I have an XPS 8500 and from what i've read(I havent cracked open the case yet) it has a 460W supply. Is the 500W requirement an overestimate and i'll be ok or should i look at a different card?
You should always have a 30% buffer of power of the required amount "needed" by your system. Power supplies start to degrade over time from spikes, sags, constant usage of peak performance and heat. If you're running at the limit of the PSU right from the start, when the PSU starts to degrade, you're going to start having issues.
