Graphics Card Problem with ping
Ad0n121
26
Soo, Since i changed my graphics card, my ping from 40-45 went 70-80, it HAS to do with the graphics card, and the port back.
Your ping shouldn't have anything to do with your GPU. The only way I can think they would relate is that your PSU (power supply unit) isn't powerful enough and thus taking power from your NIC (Network Interface Card) to support the GPU.
Please let us know more about the machine you're working with. Things like:
CPU:
GPU:
PSU:
Motherboard:
RAM:
NIC:
P.S. It's also not a good idea to take a contentious attitude with people who are only trying to help you!
Network interface card.
Edit: There is always the possibility that whilst you were changing your graphics card you could have knocked or even touched the NIC which could have caused minor damage causing it not too function properly. Unlikely but possible.
I wouldn't change it just yet,
When did you change your graphics card? How many times has your ping been sitting at a level higher than it previously used to be? If only once or twice it could be down to a high amount of traffic going to the server and have nothing to do with your PC.
The chipset that is on the motherboard.
"In a computer system, a chipset is a set of electronic components in an integrated circuit that manages the data flow between the processor, memory and peripherals. It is usually found on the motherboard. Chipsets are usually designed to work with a specific family of microprocessors"
