nippondrifterae111 :
I'm not sure if this is in the right area, but lately I've been having this problem where my screen will spaz out and I'll have to restart my computer to correct the issue and It'll be fine for maybe a day or 2, maybe less and do it again. At first I thought it was because I was having memory issues, but I was able to solve that problem, but I still have the screen doing it's weird thing. Any help is welcome and again, if I'm posting in the wrong section, sorry. I upgraded my graphics card over a year ago I believe from a Sapphire 4670 to a HIS iCooler 7770 and haven't had any problems up until maybe a month ago. If you need more specs, let me know and I'll post more. I'm also Windows 7 and Intel i5.
http://
Your screen is spazing out for several reasons. One that is already mentioned is the fact your gpu is overheating.
1. Post your specs, overclock?
Intel I5 750, Biostar Motherboard T5XE CFX-SLI, Antec 650W Earthwatts PSU, HIS iCooler H777F1G2M Radeon HD 7770 GHz Edition 1GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
I don't overclock.
2. If you are overclocking your gpu, you need to cool it by manually adjusting the fans. MSI afterburner is a good program to do overclocking. And if you overclock your memory, it spazes out because it can't handle the clock rate.
I'll have to check on the memory part. I was having memory issues, but I was able to solve them. I was doing basic things like browsing the internet or streaming multiple videos and my memory was going really high and then the screen would go out and the video for the stream would red out. Haven't had the memory or red out for videos since fixing the issue.
3. Depending if you are using AMD cpu. If you are overclocking CPU in games, certain games do not like CPU overclocks. This often happens to me in Ubisoft games. The Northbriduge is being choked up by your HyperTransport sync. Increase your NB frequency keeping HT same.
I tend to run games at mid level and lately, I haven't played any high graphics games.
4. If you are not overclocking anything and your screen is spazzing out it means your gpu is starting to fail.
