Graphics Card problem =(
EmoblazeXD
31
I bought a Forsa GTX 650 1GB DDR 5 and a Cooler Master Thunder 500W PSU
When I installed the gpu and started the pc it showed some lines in the starting menu (where you can open bios etc) and when at windows loading screen it shut down so I called a mechanic and he said my motherboard doesn't supports this gpu. Is it true ?
My Mobo -> Gigabyle G31M-ES2L
Processor -> Intel Core2Duo E7400 2.8 Ghz
Ram-> 4GB DDR 2
It's working fine with my old GPU ATI radeon HD 4350
Help !!
I did not get the windows loading screen :/ Just when it's time form the windows loading screen to come, it goes black and then turns off
