Graphics Card Problems
Sep 20, 2018
So I have a RX580 was working fine then I get home from work turn on my pc and nothing comes out on screen I tried in plugging the GPU and plugging it back in and nothing. I plugged in my 1050ti I also have and everything works fine. Anyone know what the problem could be with the RX580? The fans spin so I know it powers on but my monitor doesn’t show anything with the RX580
do you have any other Cable connection method to test out?
like HDMI or DVI or DP? try switching between them and check out if that solves the issue.
Also, whats the Exact System Specs you have? Maybe you are trying to connect that Video Card with a very tiny PSU and causes to power up to a certain point...
It’s a pre built PC from cyber power if no one here can help me fix it I’m gonna have to just warranty it
And no My monitor doesn’t have the other stuff just hdmi and another one I don’t have
