graphics card suggestion required for 3 monitor stock market trading setup
prabinseth
Hi All,
I am complete novice in terms computer components. I am planning to get a graphics card for a 3 monitor display setup. I am trader by profession. Please help me choose one. Lets me tell you what i have
1. CPU : AMD phenom II X4 840
2. Existing graphics card : ati radeon hd 5400 series ( 1DVI + 1 HDMI + 1 VGA )
3. mainboard : gigabyte ga-78lmt-s2p ( 1 DVI + 1 VGA )
4. ram : 8 gb
5. os : windows 7
6. monitors : 2 x Dell S2240 L ( hdmi+ vga) , 1 x Dell ST2220M ( DVI+vga)
7. Cables : 1 x HDMI cable , 1 x DVI cable , 1 x long VGA cable
Right now i can connect 2 monitors with my graphics card ( 1 dvi+ 1 HDMi ). But i felt graphics has become very slow when i use two monitors with my existing card. And if i connect my 3rd monitor to the vga port it does not work at all.
Now feel that i need to replace my existing graphics card to get a smooth performance ( and easy my eyes too as i sit 12-15 hours a day in front of computers screens with fast updating stock prices , charts) .
Following thing i am ready to purchase
# a new graphics card with at least 3 monitor support
# addition cables / adaptor if required
Max budget : $ 100 - 165
Please suggest me a graphics card which i can buy in India ( preferably online i.e. flipkart.com etc. ). If i get it from Amazon.com it will be too late to be delivered in India .
prabinseth
Thanks for your prompt reply. But i feel that if i use my monitors at 1920 x 1080 resolutions settings screen transitions becomes slow. I mean to say if i move some open window a bit faster then movements are not at all smooth. Even i maximise and minimise the windows in quick successions then its not at all smooth.
so i feel that my existing card is not even capable of driving two monitors at 1920 x 1080 resolutions which is essential for me. As its a trading setup screen updations should be quite fast and smooth.
Could you please suggest me accordingly. I am ready to replace my existing card if required to get a good performance card under my budget of $160.
deathcall666
264
44
I have the best solution a r7 250x 110$http://www.amazon.com/gp/aw/d/B00I0Y0BKW?cache=3489d62e454432eb4c7a0c43ebcf79d6&pi=AC_SX110_SY165_QL70&qid=1404524620&sr=8-8#ref=mp_s_a_1_8
It has eyefinity 4 so you can connect 4 displays
prabinseth
Hi,
Thanks for the solution but. I have 3 monitors. 2 HDMI and 1 DVI.
How do i connect my 2 HDMI monitor to above card because it has only one and a displayport. And non of my monitors have display port.
Please suggets.
